hotpoint FDW80 wont circulate water/wash
11 Aug 2009
West Midlands
I have a HOTPOINT FDW80 and at present wont circulate any water during the wash cycle. When in the wash cycle the water is coming up from the filter and water remining at the bottom of the dishwasher and not circulating
Has anyone got any ideas as to what this might be
Many Thanks
Sounds like you have a problem with the water pump or the controller :cry: you need to perform some electrical checks at the motor but don't atemp this is you don't know what your doing :confused:
sorry!!
circulation pump needs replacing cost about 80 quid
underneath mc .tip mc upside down remove 6 screws on the base.circulation pump right in front a big pump with a metal spring on it .just pulls off .
mc = machine .at the back of circulation pump next to big spring is a small slot in the centre of the pump see it it turns with a small screw driver should spin freely .
I have the same problem but the pump spins freely by hand yet does not move when powered. Is there a control board and if so how can I test it?
