The drum bearings on my Hotpoint FEW12P have gone. Hunting round the internet, I believe because I have a plastic drum pulley, that the bearings are the smaller 30mm type. This means I am quite likely to have to replace the spider and rear half of the drum as well as the bearings. This looks very expensive. However there is also a later type complete welded drum assembly for about £90.00 listed for this machine.
Does anyone know if I can just fit the later welded drum assembly or will some of my existing parts then not fit. For instance would I need to change to the aluminium pulley. Many thanks
