Hi, was wandering if anyone has done this:
I am looking to take the hinges off my fridge freezer and putting them on the other side so i can open the door from right to left.
There are screw holes on the other side so it just looks as though i can unscrew and refit on other side.
All the hinges look reversible - apart from the top right one. It seems a little odd that all but one can be moved and reversed.
The top hinge bends up to meet a spacer and then the screw hole - if it is swapped to the other side it would bend down to meet the door and wouldnt need the spacer - is this correct?
Has anyone done this reversal and is it just a case of moving the top hinge and swapping it over or is a special lefthand hinge needed?
Would appreciate any hints and tips that made the job easier - I don't want to unsrew the whole door assembly only to find the screw/hinge wont fit.
many thanks
Jez
many thanks
Jez
