Hi All,
thanks in advance for you advice.
I have a Hotpoint FFP187B in the garage, went into today and there was a funny smell, you guessed it,no cooling and everything defrosted!
I 'think' it may be a thermistat issue.
The lights appear to be working normally (and the small fan in the freezer section inside is also operational), however both the freezer and Fridge sections are at room temperature. The fridge has not been moved in several months.
I tried the old turning off and on at the wall trick, no joy, and have tried playing around with the temperature controller, there are no clicks or anything, however one of the attempts at rotating the thermostat did result in the condenser kicking in (and I could hear gases/ liquid moving. However stupidly I turned the dial back and it stopped again, and I have been unable to repeat it., hence my thought about the thermostat.
Any advice or other things to check?
