Hotpoint quarius 1200 de luxe 9549 - identify part please
22 May 2005
Hi all,
sister's got the above machine & said it won't spin with clothes in, but will spin without a load in. I thought it was the motor brushes, so replaced them. Now her fella's told me differently.....
When you start a wash & the drum fills, that's when it should slowly turn. You hear a click but it won't rotate. (It still spins without load though, with the new brushes in)
Can I ask.......what is the small white plastic assembly positioned above the motor's shaft? It looks like it's sitting on the shaft & belt. Should it be sitting 1/2 on the belt & 1/2 on the shaft? because it is.
Cheers,
Julian
sounds like you mean the pecker, look here
it has noting to do with spin, regretfully it sounds like the motor (i too would have changed brushes first)
The old GEC type motor is now obsolete but there are still some replacement armatures available which may enable this elderly machine to be repaired cost effectively.
