I have been given a hotpint dryer, model tdl31. The known problem is that the drum wouldn't turn but htere was heat, the first thing they tried was to replace the belt. This did not help.
The unit was then given to me. On opening the dryer i have seen 5 wires which have been pulled out from their conectors, two of which i have traced to come from the buzzer, the other 3 however i am not sure where they go (2 blue and 1 brown/white).
Does anyone have a circuit diagram for this dryer or even a photograph of the wiring in the top(around the timer area).
Once i have put these wires back where they should be i can then trace the orginal fault.
thanks
thanks
