Hi my tumble dryer isn't heating up.
I have removed the back and one of the two thermostats shows continuity (when the connections are removed from it). The other one doesn't
I did try running it with the faulty thermostat isolated but the lower heat setting still didn't kick in. I was hoping that doing so would confirm if the heating element was Ok. Should it have worked?
Are there separate checks that I need to conduct on the element? Or is it likely that replacing the two thermostats will suffice?
Thanks in advance
Thanks in advance
