I keep getting error code f 02 and the machine tries to start but keeps stalling is this easy to remedy . F02 means the motor is jammed or the tacho is detached.
Cheers Lecky758,
I have had a good look at the back of the machine don't know where the tacho would be so don't know if it is detached or not, the machine tries to go through the cycle the water valve cuts in momentarily then stops when set but keeps cutting out ie goes to start then stops then tries again; the drain out pump works when I cancel the cycle and the 2 minute code comes on but the main drive that spins the drum does not seem to work at all.
The brushes are mounted towards the rear end of the motor and do wear down.
The tacho is a small disc like object fitted to the back end in the centre of the motor (two thin wires leading from it to the connector block)
