Hotpoint ultima wma doorlock light flashing
1 Dec 2008
Yorkshire
Can somebody please advise me on a problem the door lock light is flashing and bleeping 5 times, the door opens, i have replaced the interlock switch and this has made no difference is the anything else i could try??? please help :)
Check the connections on the pcb at the top one is poss loose.
Rocks 1 you was right the black wire had come out of the connector plug i carnt get the wire back into the connector so im assuming this will have to be another part to purchase?? thank you so much
Then you need a wiring harness unless you can join/ solder the wire.
