Hi Guys
the Hotpoint washer is 18 months old and has had no faults previously.
Yesterday it tripped the Fuse box washing machine RCD, and blew the fuse in the machine's plug.
I replaced the fuse and flicked the wall socket switch (which I had checked was ok by powering the kettle), and the Hotpoint had no display and no buttons, on/off etc, worked.
I checked the cable fuse again and it was ok, the wall socket ok, and no RCD trip in the fuse box.
I checked the main cable with a tester and it showed that power was entering the machine, so I took the top off and checked from where the cable enters and the power was still getting through to the internals.
I checked the red cables through to blue box connector on the side of the machine, then beyond that to the cable to the door, to the front display, and the cable that runs down the back of the machine to the motor (?). All show that power is getting through, yet the display and the on/ off button don't work.
Any ideas where I go from here is appreciated, thanks
