HotPoint VBXR1070W0WW washing machine won't drain properly
7 Aug 2008
Illinois
The machine spins and will drain for a few seconds but then suddenly stop. This seems to go on forever but the machine never drains all the way. There is some back draft of the water as well. I checked the pump and all hoses and they all seem fine. I then attempted to check the pump switch and pressure chamber. The chamber is clean and when I blew into the the bottom of the hose, I heard the switch click. Also, when I blow through the bottom of the hose, into the pressure switch, the machine drains properly. Does this mean the pump switch is bad? I thought if I heard the click, the switch was good. I'm stumped! And my wife doesn't like the idea of having to blow into a hose to do the laundry. Please help. If it's just the pump switch I can handle it, but I don't want to start replacing parts that don't need to be replaced. Thanks.
I checked all drains and there is no blockage or back flow problem. I then replaced the pressure switch and nothing changed. The washer does drain if you blow a little pressure into the pressure switch. The pressure needs to be maintained utill the washer fully drains. Then once drained, the cycle will continue. I just don't know why there doesn't seem to be enough pressure building in the chamber to set the pressure switch off. The chamber is clear. I even blew into the chamber and didn't feel any obstruction or blockage. Need help!
