Hotpoint wash/dryer (WD64) drain was blocked, now won't run
bz
12 Oct 2012
Hello, my Hotpoint washer-dryer stopped draining during the cycle, then stopped working altogether after a few attempts at restarting the cycle.
I discovered a near-total block of the drain filter and cleaned it out, but needless to say the machine still won't work. There's no sign of operation whatsoever (no lights or anything).
Is my likeliest problem a pump fault? What else should I look for?
Thank you in advance.
Push the door or give it a good slam , door switch poss dodgy.
