hotpoint washing machine wma64 bearings
27 Nov 2008
Liverpool
Noisy drum whilst spinning even when I remove the belt.Suspect bearings need replacing.I have removed top from machine, how do i remove casing to get at rear of drum to access bearings?
wht you have to ask yourself is, have you the tools to get the old bearings out and new ones in?
you will also need a new drum support (spider), heater, front plate seal.
remove consol panel /dispenser /front panel /concrete weights /then remove drum and then split drum in half to get to bearing good luck :LOL:
Hi In the broadest of terms Rocks1 is correct in his description of how to get to the bearings, but as you don’t even know how to access the container the information will be useless to you, really you need to buy a step by step guide on the repair of WMA64 machines. Try here http://www.selfix-uk.co.uk:cool:
