Hi guys,
Just bought the above machine as I was looking for a quiet machine for a small kitchen and the so called "Sssh" technology was recommended by the shop assistant.
It is quiet, even the spin except when it is pumping out (which seems to be a lot of each cycles time) and it has been so noisy compared to any other machines I have ever had on the 5-6 times I have used it.
I have had the Hotpoint engineer out and needless to say it didnt make the loud grating/vibrating type noise when he was here. He really didnt believe me, that was even with me playing recordings of the noise I had taken and my daughter backing me up. The pump is clear of foreign items so that is not the issue and his computer diagnostic tool says I haven't been abusive to the machine in any way!
The only difference is that he didnt use detergent when he ran the cycles to test it. So I can't exchange it as apparently the machine is fine! The machine is supposed to be 56db and I don't have a noise meter to hand to measure it. The noise the pump made when he was here was tolerable but still not great.
He also commented that the "Sssh" technology only applies to the motor and nothing else. The new machines also apparently use less water and some built in non return water ball mechanism will make noise.
And needless to say the grating pump noise is right back now he is gone and I am using detergent! Maybe the ball mechanism is disrupted my soap suds? However it does it on rinse too.
Before I get into a wrangle with the shop about the machine and trade descriptions etc etc I plan to vary the detergent amount and type to see if that helps and also maybe try to pack some sound proofing around the pump area just to see if I can tolerate it.
Would anyone be able to offer any advice or have any experience of this issue?
And if I cannot live with the intrusive pump noise and I can manage to get it exchanged, any advice on a nice quiet machine?? I am not concerned about water consumpion if I can get a quiet machine.
Thanks in advance for any help offered
