My Hotpoint WD 640 washer/dryer suddenly started fusing my RCD protected circuit. Disconnected washer motor and washer heater, problem persisted. Disconnected dryer heater, problem solved. Do I just replace the dryer heater or could there be another problem?
If you reconnected the other 2 components then it is probably just the drier element needs replacing. Presuming you have removed any contamination that might cause it to track to earth i.e. fluff, muck etc.
