Hello All, I have a fault with the washer/drier that has me puzzled.
It first stopped drying, giving no heat and clothes were still wet, so removed the back, removed the pump and bottom hose to clean out the filter which was clogged, reassembled the machine and checked the heater element with a multimeter which was fine.
I found that the stat nearest the front of the heater box measured o/c, so reset it by inserting a fine needle, then tested the machine.
It now heats up again in drying cycle, but seems to run fine on low heat setting, but when the "drying high heat button" is selected, it seems to run fine for about 15 mins, then starts to spin, then after a while it also gives the error code lights of 1, 2, and 4, together with a flashing on/off light.
I presume this is error code f13 which is dryer ntc/ fan motor .
Would this possibly be the other stat that is faulty, and hence the machine is overheating, or is it some other problem.
Also the clothes seem very damp still.
