Hotpoint WD420P washer dryer, flashing light.
19 Dec 2007
Bournemouth
Hi. My (frankly rubbish) Hotpoint WD420P washer dryer has broken again.
In starting a wash it stops and flashes the 'Reduce Creases' light (second one down) along with the power light.
I've read somewhere before it's possible to work out what the error is based on which light it is against a table.
I've seen a table here //www.diynot.com/forums/viewtopic.php?t=163622
That could be my problem but I'm not sure which way to read my lights.
If it is a stuck pressure switch, where is that? Can I just manually actuate it a few times to get it unstuck?
Thanks for reading.
Clen filter ,blow down presure pipe ,check connections on pcb
