- Joined
- 17 Jun 2014
- Messages
- 2
- Reaction score
- 0
- Country
If anyone can help I'd be very grateful. I have a Hotpoint WD440 washer/dryer that is about 4 years old. The last load of laundry washed fine, and the machine finished the cycle as normal. It did sound a bit different when it was spinning - perhaps a bit like an ungreased bearing. But it finished fine. Now it won't start up, no matter what cycle I select.
Usual process was to shut door, press ON button, then press START button. WASH light will come on, then DOOR LOCKED light will come one, and it fills.
Now, today, I note that the DOOR LOCKED light doesn't come on. It doesn't lock and therefore it won't fill/spin/drain.
I replaced the interlock which latches/locks the door, as that was only £5 from ebay and plugs in very simply. No joy. I rocked the drum, reseated all connectors and tried again to no avail. Visual inspection of PCB could not find any blown components, burn marks, or odd stains.
I then had my father-in-law round, and he put a multimeter across various things. The brushes must be ok as he saw a reading across the armature (we undid the spade connector on one side of motor first). We checked continuity across the heater element in the dryer box, and various other points.
(We were a bit unsure about the temperature sensor/cutout in the dryer box. It read open circuit when cold which surprised us. We disconnected it and stuffed a bit of wire in to form a closed circuit, in case that encouraged the machine to turn on...but no.)
So I guess it can only be the PCB? A new one is £140 plus VAT, and most places want £53-84 labour charge, plus VAT, to fit it. So I might as well buy a new machine for £220 (no dryer) or £300 (with dryer)!
Is there anything else I can check?
Thank you all.
Thank you all.
