Hotpoint WD440P Lights flashing
29 Aug 2007
Buckinghamshire
My Hotpoint WD440P started playing up yesterday. The 'Drying High Heat', 'Reduce Creases' and On/Off lights started flashing and the drying program wouldn't start. I know the Hotpoint machines flash certain lights to indicate what might be wrong. Anyone know what the above combo means?
I was so annoyed with as it the 5th thing to go wrong this week so I kicked it! It started working after that :D
Not sure how long that will last though!
Posted: Thu Feb 25, 2010 21:09 Post Subject:
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
