Hotpoint WDL520 Drying Problem
1 Apr 2011
Yorkshire
Hi everyone.
My Mum has had a Hotpoint WDL520 Aquarius Washer/Dryer for around 18 months/ 2 years now and we've had no problems with it until the past few weeks.
When it goes into a drying cycle the machine just does not get hot. I've seen people saying in other topics about this machine and similar that there are error codes which flash on the front of the machine but in my case this does not happen. The machine acts as if it is working fine and completes the full drying cycle, it just does not get hot in the process.
I'm fairly handy so I don't mind opening the machine and fiddling with/replacing parts but I thought I'd call upon the wisdom of you folks who are more likely to know what exactly is the problem before I go taking the machine apart.
If the machines not fixed then my Mum is going to get a new one and throw this one away. I hate the thought of it going to waste over something as silly as a blocked up filter or a thermostat that needs resetting. If you need to ask me any questions to help you diagnose the problem then feel free and thanks in advance.
Heater gone on the heater box. Remove lid at look for 2 brass nuts on the heater box check heater with a tester just to be sure.
Hi Rocks1, thanks for your quick reply.
I know this will probably make more sense to me once I get to see the actual insides of the machine but which section of it should I be testing?
Also what sort of reading is normal? or is it just to see whether there is any reading at all?
Cheers.
