Hi there, i have a hotpoint wf321g that is just over 3 years old, about a week ago my wife turned it on and there was a big bang and the machine did not respond at all, so i stripped it down and looked at the main control module, i could see some black marks on both sides of the board and the main damage was where a leg had blown off of a capacitor, there was also a few drops of water on the board, so i replaced the board, upon stripping it further i found the pump was clogged with about £2 in loose change, so i cleaned it all out and also took the black pipe that runs from the drum to the pump (has a ball inside) off and cleaned it as there was alot of soap scum all inside, i also had a good feel (as far as my little fingers can reach) around in between the drum and the casing and could not feel any obstructions, so i went to do the first cycle and the 1st light (wash enhance) was flashing along with the on/off light, i got a little leaflet with the pcb that said the cause of this was the pressure switch, so i replaced it, but it still did it, here is what i have found so far but am stuck now,
if i put the machine on fast spin with the little black pipe connected to the pressure switch, the machine will rotate slowly a couple of times, then the pump will start and the wash enhance light will start flashing and it will stay like that with the pump spinning, but if i take the pipe off the pressure switch, and blow into the pressure switch the machine will rotate slowly endlessly, however if i blow into the pressure switch for a couple of minutes then turn the machine off, connect the black pipe to the pressure switch then turn the machine back on, it will resume the cycke then start the fast spin for 1 cycle, then the lights start flashing, i have spent all day yesterday and today trying to sort it out but am completely stuck now, has anybody got any ideas?
