my hotpoint aquarius wf541 has decieded it wont pump out the water at the end of the cycle,everything works fine until it needs to empty,originally the fault code i found was a pump blockage or fault,i found the pump burnt out due to a coin jamming the impeller.after replacing the pump the fault is still apparent but the fault code is different,now it flashes the reduced creases and mini load lights at the end of the cycle,could someone please point me in the right direction as to what it could be,i have checked the condition of all the wiring which all checks out fine,i am leaning toward the circuit board having failed although this also looks fine.when it originally failed it tripped the fusebox
