Hi Guys,
Tried this on ukwhitegoods forums but thought I would throw it out here to, to you knowledgable lot.
I've got a Hotpoint Aquarius WF560 1600 Spin washing machine.
Problem is it won't lock the door to start the washing cycle, it will just sit there with the power light on. Been having a read about and some fingers are pointing to the door interlock switch.
If you bypass this switch ( Open it up and manually work the contact with an insulated screwdriver - care anyone else that does this it's 240V) the machine the door lock light illuminates and the cycle starts. Grand, I thought, It's the switch, although I swapped that out with a new unit today and nothing ( same behaviour)
Anyone else had a similar issue to this? Someone else has mentioned that it may be the PCB that is not sending the signal to the interlock to lock the door.
I don't really want to start swapping out more components, so if anyone has had a similar experience and solved it I would be very greatful for any advice!
Thanks all
Thanks all
