Hotpoint WF640 displays "test" in the LCD. It runs through some sort of test cycle and then stops. Each time I try to select a program as soon as it starts it goes to the test cycle. Any ideas??
Found the answer elsewhere on this site......and it WORKS!!!!
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
