Hotpoint wm
3 Sep 2005
Re: Hotpoint Aquariius 900
drum during agitation stages spins too fast, (forward and reverse)causing banging noise!!
Please advise what could be causing this fault.
Thanks,
Hassan
I take it even when empty it spins too fas? it sounds like the tacho mgnet is either broken, loose or not there.
un plug m/c take lid off, look at bak of motor, there is a round magnet screwed to the motor shaft, it should be tight and in one piece
I have since then replaced the motor and the timer, one by one and the problem is still there.
Any ideas?
