Hi
Old Hotpoint WM22 started sounding loud on spin, and sounds a bit 'crusty ' when turning the drum manually. Time for a bearing change.
This evening I stripped the machine down- front panel off, front of drum exposed, belt and pulley off. Now that the belt and pulley are off, the drum turns very freely with no resistance and I noticed that its a lot quieter! It doesn't really sound like bad bearings anymore.
Is this normal for bad bearings to sound quieter when there is no resistance? I really don't want to have to change the bearingd if I don't have to as last time I did it, it was a complete nightmare trying to get the old bearing out (and the new one didn't go in much better either!).
I did try to post a video here with the noise, but the file was too big. If anyone wants to listen I can send it to them.
Only thing is, if the bearings are good then something else is causing the loud spin.
Cheers.
Cheers.
