When the washing maching tries to turn the drum, the motor is working/spinning, but the belt is periodically slipping - more often than not it will turn the drum (7 times out of 10?), other times its stationary as the motor visibly spins. A few years ago I had to replace the motor - will the belt be getting to the time of replacement or do you think its the tension? How much tension is required?
Even with reduced loads, the same problem happens.
thanks
Brian
thanks
Brian
