The problem started when the bearings went. Even after they had been replaced the power still tripped out. I took the motor apart and cleaned up the area with which the brushs make contact, fitted new brushs but this has not solved the problem. The machine works fine on a spin cycle, but as soon as you select a wash cycle it fills up with water until it reachs roughly the bottom of the drum then the power trips off. To get the machine to drain I have to tilt the washer to about 45 degrees to the left (when viewed from the front). I've looked at the heater element but cannot see any obvious damage. The only component I have left to check is a small circular item next to the control unit that is connectd to the base of the outter drum by a clear tube, but I don't know what it is or what it does.
