Hotpoint WM64 Help needed No power
22 Nov 2011
Hello i have a Hotpoint WM64 aquarius1200
From doing a wash the machine powered down mid cycle and will not power back up no red light on front.
I have removed the lid checked to see if theirs a live feed coming in live in fine.
I looked at someone else thread here and i think i have a problem much like it or alike.
Removed the switch for the door has 3 wires Com been Brown,neutral Black,Live Red
Have checked and seems to be braking fine when using the on off switch and checking for life and brakes the circuit when turned on and off using the switch but using the the door switch when pushing in to connect it makes no difference
For the live and com do i connect these 2 together to test. What do i do with the neutral do i leave this plugged in for the door switch or remove
Netural suppy has gone down , check the first block on the pcb. Track will be blown.
How do i check this or remove the pcb i am assuming the pcb is the power circuit board that holds all the wires and everything else on.
Also is this an easy fix or does this require a new pcb.
Am no tech at this stuff novice but i know bits here n there to work around it
Remove consol panel then the two screws that hold the timer in place.
ok i have the pcb total removed from the washer what am i looking for on the pcb.
Would i be looking for something that's blown or burnt. If so i do not see anything that's burnt out or discolored
The very first block of wires. Should be black , remove the block of wires and underneath should be a copper track on the edge that will poss be broken / burnt.
Gone down all the tracks on the pcb nothing burnt on it also tested each one with meter to test and seems to be all connecting to each other fine.
Are you referring to the wire or the circuit board as looked at both don't have anything wrong
I have tho found the main switch on off seems to be partly melted together but seems to be turning on and off ok. But i have ordered replacement for that so we know its not that and to be safe too. It might be this i dont know.
Or it could be the door switch
any ideas how i can test to fire up system to see if powers up
The on off switch should have live and netrual on the sides , do they have continuity. If its melted then that's your problem. Only things that cause it to be dead is pcb or on off switch. The door lock blow these on the pcb
Yes there's continuity and when pressing switch in and pushing back out it works as a switch is meant to
For pcb you where you explained i have looked and also snapped shot image everything seems clean on it
Is that what you where referring to.
Hope i can get this working again or its a new washer ore repair and already got quote of £100 +
That looks ok. You can link door switch out by linking comm and live together. If that fires up door switch is at fault.
Thx for all the help and advise given so far. I will wait til li get replacement switch for on/off then try that and go from there.
1 question lol where do all the connections go back man i feel dumb i did have everything lade out but dam cats jumped up knocked everything over n wires all over place now
The timer is in situ. First is a black block , then blue green then black or red to motor. That's the top of pcb. Bottom are. Grey violet green.
Ok i hope i got this in order.
They are 2 wire that's connecting too hope everything is in right order now
This is the bottom
Is everything ok there or do i need to move that blue one over to the next
Top part
I really do appreciate your help here that you have given me. You need a medal of honor for your help
Yep that all looks good.
If i was local to where you live i would buy you a drink for all the help you given me . Do you have a shop for parts a good website.
I used this site to get the switch part well made the inquire for to make sure its for the washer i have.
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=645086&query=hotpoint wm64 &model=wm64
If i find its not that would i be best looking at this
http://www.4ourhouse.co.uk/cgi-bin/...oint WM64X&model=WM64X&path=66991,52516:66992
and after that go from there if still not working
