hi, could somebody please tell me where the pump is cause i want to check for possible blockages as in the past weve not had any luck with washers thanks
There is a panel at the bottom of the back to get at the pump and associated plumbing. If you take off the big hose from the bottom of the drum you will find it contains a cage with a plastic ball in the middle. Any nails, hair grips etc can stop this ball from seating properly. If you want to avoid blockages make sure you always check pockets and if you are washing childrens socks or other small items, always put them in a net bag.
