hotpoint wma63 door interloock to pcb connection point
16 Mar 2015
Hampshire
bearings went on my hotpoint wma63 washing machine so i replaced them successfully. now i have the machine back together and all is well except...
i'm getting the red flashing lock symbol, so the machine wont proceed to the programs. i have found the problem. the wiring connector that comes from the door interlock to the pcb isn't connected to it, but i cant identify where it has come off of on the board though. please help.
kind regards
ntepy :)
You will need to be absolutely sure you fit it back in the correct place and correct way around.
Don't assume it fits in the 1st place you find.
Photo of connector and board helpful.
You will probably need to remove the board from the rear/side panel to view probably.
Should really be obvious where it goes.
