- Joined
- 19 Mar 2007
- Messages
- 731
- Reaction score
- 5
- Country
ok guys....washing machine works fine, but fails to drain out the water after washing, hence drum is filled with water and lock symbol displayed on panel...so i turned power off machine, and with a bit of string managed to open the door..took out as much water as i can, renmoved what i presume is the filter located on the base of the drum at the back..see pic, nothing really blocking the filter, so itook off drain hose connected to sink , ran water through it and it flowed out at the other end so drain hose is not blocked....i then removed the drain pump, to see if the impelller was jammed or clogged, but that was fine...i assemble everything back...and ran the machine with load of clothes , worked fine for a day , washed a couple of loads and the water drained out..yipee !! i thought fixed it...but next day same problem...followed this vid here http://www.youtube.com/watch?v=zKjKi50YBpI i get 170 ohms reading..ive orederd a pump, not very expensive, but ive been told there shud be resistance across the terminals such as the one im getting, but in vid it says reading shud be very low...any ideas or advice ?...been told to connect the pump to a 240v supply and check if its working..dont want to do that seems kind a danagerous..lol
