- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
After it had been on for about an hour all the lights on my Hotpoint WML540 suddenly started blinking - I opened the door and water gushed out (should have looked first!) and quickly closed it. Turned the machine to pump out ('C' on the dial) and all I get is a grinding noise.
Turned it fully off (hold down power button), select normal wash ('2' on the dial) and it's now going through the early cycle so the pump hasn't yet been activated again, have to see what happens next. However, assuming that the pump is now faulty how do I empty the machine and release the lock so I can at least get my washing out?
Not sure if it's related but prior to putting on the machine earlier this morning the water pressure was low (it happens in my area at times) - could that have been responsible for the pump issue? The machine is over ten years old so maybe the pump was getting to the end of its life and something related to low water pressure caused it to fail?
