typically as i am about to move house the washing machine has started to play up, water has started to leak from the door, i have cleaned out all the pipes and filter but it continues to leak, would it be the door seal
i have been running it empty and it also appears to be filling up to much and then leaking around the door seal
if you think it is the seal is it easy to replace
your thoughts would be much appreciated
ivan m
ivan m
