I’m currently in the process of renovating a house which needs all the plaster hacking off all the walls and total electrical rewire. As I having this work done, I thought that I would just as well bring the house up to a ‘well above average’ (I’m not talking ‘state of the art’) standard on the audio / visual front as well.
I’ve been looking on various forums for different suggestions and have come to some form of first draft, but would recommend your comments or suggestions –
Satellite TV
Changing the current Satellite LNB to a Techomate Octo LNB and running a Triax ‘shotgun’ (twin) cable to the Living Room, Dining Room and all Bedrooms.
Possibility of changing the dish to 80cm motorised set-up at a later date.
Freeview TV
Fitting a TV aerial connecting to an electrical powered booster (based in the attic) with co-axial cable running to the Living Room, Dining Room, Kitchen and all Bedrooms.
Network
The first phone point comes into the house through the front window, will then need to run a cable to under the stairs (where the router will be housed) and running Cat5e to each room in the house.
Possibility of a second wi-fi router at the top of the landing.
Phone
A phone point in each room
Audio
Either Cat5e or speaker wire either to each room (i.e. whole house) or from the living room to landing.
Electrical Sockets
Min of 3 (double) needed in the living room (TV, DVD, Receiver, Amp, CD Player, PS3)
I’m guessing a min of 2 (double) in the other rooms in the house?
Other Electrical
Was planning to fit a mains operated smoke alarm and burglar alarm (should the house ever be rented or empty).
Considerations:
Cost – I want to put in some good networks whilst I have the chance, but can’t afford a top of the range solution
TV – the Freeview picture is very good, but the channel choice is extremely limited. Freesat has a huge choice, but often drops in poor weather. Therefore the proposal for both an aerial and a dish.
Network – this is an old house and I’ve noticed in the other Victorian houses that I’ve lived in that the wi-fi signal doesn’t travel too well, therefore the proposal for network point in each room.
Comments and suggestions appreciated!
Satellite TV
Freeview TV
Network
Phone
Audio
Electrical Sockets
Other Electrical
Considerations:
