for some reason my house is never getting hot.....
I have a Potterton Flamingo 40 boiler with a Grunfos UPS 15-15 pump for the central heating system. I have 7 K2 radiators (recently changed by myself in place of the old single panel rad's) in a mid terrace house and never feel that the house heats up as much as it should do.
I would reckon since changing over the rad's from the old style single panel ones that the pump is now stretched and it takes a little while for the rads to heat up, but after being on for a few hours I would expect all rooms to get very warm? Each room has a honeywell Thermostatic Rad valve and it is turned up to 6!
A good example is in the bedroom. Rad is spec'd to give out approx 6000 BTU's and using an online calculator it reckons that the room only requires 4500 BTU's. The room is never overly warm
Can anyone give me a heads up?
Cheers
Cheers
