So i've been putting up with this for a while, but i'm wondering if theres anything i'm overlooking or doing wrong.
We have a 1920's semi, brick built cavity walls over two floors. 1st generation double glazing all round, thats getting on a bit. 300mm rockwool loft insulation, no cavity wall insulation. 20kw system boiler feeding radiators in each room.
In the cold weather (ie now) i find the house is almost impossible to keep warm. I work from home, but i avoid running the heating all day as it just seems to chew through gas and not really make much of a dent in the temperature. I tend to sit in the front room at my desk, with the door closed, and 1kw of fan heater topping up the warmth during the day. This gets the room up to a comfortable 20-21c and holds it there with a ~50% duty cycle. The rest of the house ofcourse is freezing.
When the boiler comes on around 5pm, the house just doesnt seem to get warm. There is three radiators downstair, one in the front room, one in the back room/lounge and one in the hall. Lounge is set to 5 on its TRV (room stat is in here), hallway and front room set to 3. Tonight for instance the lounge temperature was at 14c at 5pm. heatings been on for an hour, and its climbed to 15.5c, and thats with the lounge door shut, if i left the door open it wouldnt have climbed at all. If the door remains shut, it'll very slowly climb and might get to 21c by the time the boiler shuts off at 10pm. The hallway and kitchen (connected together essentially) is permanently freezing, cranking the hall radiator up seems to have little to no effect. This also means that any time you move between the rooms or goto the kitchen, any heat you've managed to build up seems to woosh away and get replaced with a cold chill from the hallway.
In the really cold weather a few weeks back, i ended up running my fan heater in the lounge more or less all evening, as the radiator was struggling to get the temp much over about 17c.
Last week i measured the flow and return pipes at the lounge radiator, and got 55c in, 40c out. I tweaked the lockshield to get it to a drop of 9c. 55c in seems a bit low, given the boiler stat is set as high as it will go. No real effect to the room temperatures. Radiators all feel hot to the touch.
I did an experiment a few weeks ago, running the boiler all day. In the time its usually off (9-5) it managed to chew through 2 units (cubic-ft) of gas and yet the rooms were still lukewarm and the hallway still freezing.
Its really getting on my nerves now, i should be able to put my heating on, and have the house heat up to a comfortable temperature, without literally sitting shivering. I wouldnt mind so much if it ripped thru the gas doing so, but chewing up gas and feeling no benefit from it is really frustrating.
Any thoughts?
I've a sneaking suspicion that the radiators are essentially too small, but that doesnt explain how the system is managing to rip thru so much gas. The heat has to be going somewhere?
Any thoughts?
