My bathroom had a light (with shaver socket) over the sink. The room has now been re-arranged and there's no longer any particular use for power at that spot on the wall.
It's about 2m off the floor and 4 or 5 inches of t&e protrude from the plaster. The point where the cable comes out is right on the vertical line where tiles will now give way to painted wall, so it won't be in the middle of an empty space and is very unlikely to be drilled or nailed into...
I assume that from this outcrop it runs vertically and into the ceiling (ground floor extension, no access from above).
Because of the location I think it will be awkward and odd to put a new light there, and I suspect that simply burying it in the plaster is not the best idea. I thought of putting a new shaver socket on it, which would fit but it's in a bit of a useless place (red cross - http://i.imgur.com/7daXAHS.png).
What would you recommend? If I can't trace the cable back and remove the whole thing then what's the safest way to hide it? Must I dig out room for a backbox and then put a blanking plate on it?
Thanks,
Thanks,
