Hi
I have a 7 by 4 metre deck with standard ridged boards. I made the terrible mistake of coating the deck with Cuprinol rollable deck 'treatment' 4 years ago when it was first installed . 12 months after the original application, I had to re-coat as it was chipped and flakey. This has happened every year since and not only do I resent spending £30 on 3 litres of this rubbish but the end result (before the chipping/flaking has even started again) is a very patchy colour (mis) match. The 'treatment' as they call it, forms a film and is more like a paint than a true stain as it just does not penetrate the wood. I suspect that the only way to fix this problem is to remove the stuff and start again. I'd be very grateful if anyone had any suggestions as to a product or process that would remove this stuff (sanding is difficult as the boards are ridged)
many thanks in advance
