Hi, I have a 3m diameter x 1m deep surface pool, which we put up each summer and take down again at the end of the season. Due to excessive dry weather here in Hampshire, we have a Temporary Usage Ban coming into effect this week which, amongst other things, bans the use of the mains water supply to fill or maintain pools (commonly referred to as a “hosepipe ban”).
I have a “pool vacuum” handheld tool which uses the mains pressure from a hosepipe to flow water through the head. This flows out through a net. The head is on a long pole. This means that I can stand outside the pool and slowly move the head over the pool’s floor. The flow of the water “sucks” up debris into the net, thereby cleaning the pool.
With the ban coming in, I will no longer have the mains pressure to flow the water through the head. So I’m looking for ideas on how to keep cleaning the pool. Over the 4 years or so of having the pool, we’ve found cleaning to be absolutely necessary to maintain water quality (in conjunction with covers, skimming, chlorine, algeacide, and of course pumping the water to maintain circulation).
I’m not interested in how to circumvent the ban (e.g. conceal the hosepipe). I’m only interested in how to keep to keep cleaning in the absence of mains pressure.
I have a spare pool pump (the basic one that came in the original box) so one idea I have is to recirculate the pool water for use with the pool vacuum. To do this, I would need an adapter to connect the pump hose (32mm, I believe) to a garden hose fitting (because the pool vacuum head is designed to accept a hosepipe’s quick connector).
Any ideas on this??
Any ideas on this??
