How is it stuck, does the handle move/not move, or does it move and not do anything like it's not connected to anything or does it open one end of the window but not the other?
If the handle is just turning and nothing happens it could be something as simple as the spindle coming away from the back of the handle, remove handle to see, bash spindle back in and it's fixed temporarily, or slightly more dramatic it could be the square drive in the gearbox where the spindle slides into could have fallen apart and now the handle will just turn.
It could also be the centre gearbox failure and it's only operating one end of the lock(see first paragraph).
There's a few variables on how a window can be stuck, it's like saying my cars broken down, how do I fix it.
Check handle first then look through the spindle hole to check the square drive is still intact
You can move the handle but it doesn't unlock, the handle is turning the square. It must be the gearbox or part of the locking mechanism at fault I think
I had a similar problem, we used to always have the window ajar and moisture must have got into the gearbox an seized it.
I found a Youtube video on how to release it involving a pair of mole grips and an allen key.
I then replaced the gearbox and the lock rods
