I've just had a new gas meter installed. My old meter was imperial and this is cubic. Even allowing for the 'multiply by 2.83 factor', my usage is now considerably higher than under the old imperial meter. Either my old meter must have been faulty - or maybe the new one.
I am trying to determine how much gas my Potterton 50eL should be using, by looking at the 'Technical Data' page of the manual. I've found
Output kW 14.65
Input kW max 18.02
Gas Rate m3/h max 1.68
Burner Pressure max 11.5
Injector Size mm 3.5
There is other data as well. Is it possible to calculate how many cubic units of gas I should be using say over 5 minutes at maximum? Any pointers greatly appreciated
Output kW 14.65
Input kW max 18.02
