How can I wall-mount a cast iron radiator?
24 Mar 2014
London
I've got a small, old-fashioned cast iron radiator that I want to fit. It's only 55cm wide by 40cm tall. So it's too short to stand on feet on the floor – but it's still very heavy. What would you use to fix it to the wall?
The radiator will expand and contract as it heats up and cools down. Allow for this when determining where on the radiator you position the brackets. The radiato must be able to move relative to at least one of the brackets other wise "creaking sounds" are likely. A resilient pad between bracket and radiator is a cure for this minor but sometimes irritating noise.
