hi all
i will try and explain
my cloakroom is approx 1.1m wide with a depth (length) of 4.5m
on the wall facing you as you walk in i have a worcester bosch 42cdi approx 1300mm from floor
below the boiler i have a wc which i am changing and puting in a boxed in cistern and then hopefully try and conceal boiler (not sure how much i can conceal but open to sugestions here) seems a bit in youre face at the moment and as i am putting in a framework to conceal cistern just thought i could try and hide as much as poss.
also on the left hand wall facing boiler i have a towel radiator which is to be replaced but i am not sure of how close i can go to boiler.
i want to keep everything above board as far as safety and regs go but am struggling for space in what is a very cold room.
i have another option of going for a narrow and tall radiator but even this would then probably hinder the removal of the casing for maintance.
quick summary
can i have a radiator which potrudes underneath boiler or can would i be better to put a floor to ceiling radiator which may or may not hinder maintance.?
can i conceal underside of boiler (pipes etc)?
kind regards and thanks to anybody who has the time and patience to help
quick summary
