I'm searching for a leak in a sealed system causing the system to need topping up every week or 10 days or so.
I replaced two rads that had weeps that had rusted a fair bit around the weeps, but there are no other leaks that I can find, no ceiling stains, no drip from the safety valve, no leaks or stains inside the boiler itself. The boiler is only three years old and looks good inside & operates well apart from this problem.
I also put in leak sealing chemicals when I changed the rads. That was two days ago & I had to top up the system again today, which I expected anyway as the system was just refilled & had some air in it. But I wondered whether the leak is still there.
I saw on another thread that someone found their leak was the coil in the immersion tank, so I wonder if this is my problem too and how common this problem was and whether there was anything simply to indicate that it is the problem?
I guess my leak sealer won't work if it's leaking into a wet tank!
