Thanks... Just read my subject dont know what happened lol doesnt make sense.
Its at about 500mm at the moment so will dig trenches a bit more deeper... but as theres no drive down yet im sure once hardcore and drive has been lated it will be 750mm deep quite easily.
You have to comply with the law.....'Water Supply (Fittings) Regulations 1999' which is quoted in the above ST doc.
Also you should be an 'Approved Plumber' to self certify and get the water company to inspect your new pipe before they do the final connection to the main. They often don't bother to inspect but insist they do need to be notified.
Thanks for responses, ST have been kept in touch all the way through but they are the hardest company to get through to even for the simplest of enquiries.
E.on have been the most efficient and helpful so far.
