I have a situation where 100mm insulation has been put on top of an unlevel concrete slab
Insulatiin boards are 400mm wide.
19mm T&G and 12mm laminate flooring to go on top.
Part of the floor will be too high, and I need to reduce the height.
Prefer not to have to grind concrete down.
How practical / easy is it to reduce the thickness of the insulation - with a hand saw, I presume?
The alternative is to apply self levelling compound to the concrete then use 70mm to 80mm insulation.
That has two negatives. Expense of buying more insulation. Lower insulation properties than 100mm (with some reduced thickness).
Q2
if I cut the insulation, it will not be a perfect contour for the uneven concrete slab so I will need to apply self levelling compound.
Should this go:
On top of the insulation (joints and edges sealed, surface primed)
On top the 19mm T&G (primed)
Or will it work on top of either. (My preference is on top of insulation)
thanks ColinK
Q2
Should this go:
thanks ColinK
