I have a (probably) silly problem. I am trying to build a wardrobe inside an old airing cubboard but am struggling to think how I can affix the shelf rails. The cupboard is build out from the corner of the room.
The problem is that the walls of the cupbard are single thickness plasterboard which means i cant drill or use butterfly fittings as the fittings will be visible on the other side of the wall and i think no more nails would not be strong enough to hold the shelf supports
I am tempted to line the interior of the cupboard with plywood no more nailed to the plasterboard and then use short screws to attach the fittings to.
Any ideas
Any ideas
