Im trying to hook up some 5050 smd LED strip lights under my kitchen cupboards and just had a few questions regarding LED drivers/transformers.
the LED Strip is 5M in length and will be cut.
60 leds/Metre
input voltage : 12v
Working Current/metre: 1.2-1.25A
Output power: 72W /5 Metre
Luminous Flux: 700-800Lumens/Metre
I plan to cut the LED Strip into a 1.8 metre length for under the kitchen cupboards. Then I want to cut and join 2 more strips for under bookshelves in the front room 1.5m each (3metre in total). Ive done quite a bit of research already - but just wanted clarification on the below:
1)Do the numbers written on the transformers just show the max they can handle without fault?
so when buying a 12v transformer/driver do I just have to make sure the total max Watts is ample to drive the length of cut LED Strip?
eg. 3m requires output requirement of 43.2 watts - so I would need a 12v 50 watt transformer....
2)could I safely use a 12v 60 watt transformer on the 1.8m length (only 25.92 watts required)? Does it just draw the current it requires and as long as its less than the max capable - there will be no problem.
3)I tried a 12v 30watt laptop transformer on the full 5metres for 20 secs or so to make sure the lights worked. they came on but, what would happen if I left this running for 12 hrs or so? (just curious!)
4)Could I use old/2nd hand laptop transformers if the watts/amps are suitable for the requirements above, or do the bought "LED drivers" have special features that laptop tranformers dont have?
thanks for any help
60 leds/Metre
input voltage : 12v
thanks for any help
