I have seen other topics with similar questions about replacing a belt but it seems to be focused on streching the belt into position.
My question is one step back, how do you get the belt in position in the first place? basically around the drum.
Is it best to approach from the front of the machine of from the back? Are there hundreds of bolts around the shaft or can the seal around the door be easy removed so I can get the belt in position.
Cheers
Richard
Cheers
Richard
